Tail_Gunner
Thread starter- Joined
- Jan 13, 2006
- 6,237
Posting this topic is not meant to be contraversail, i am looking for a litte more insight into the process. Personally i have broken in new car's for the past 15 years (demo's every 6 months) and have found that if you do run them hard for the first 1500 to 3000 miles they do run stronger and get better gas economy. I should also state after the intial 1500 -3000 miles they start burning oil and this has been reconsized as the seating process, during this time i have been very gentle with the motor and after it burns a quart or so it stops this process.
Now here is the link http://www.mototuneusa.com/break_in_secrets.htm
Is anyone in the know.....do they use the same honing process for marine engine's as they do car engines? I can see no reason why they would use a different process but then again this is a marine engine and i should add i just finished breaking in a new boat and followed the mfg guidelines, there were just to many variables to take the chance aka different cams, the heat the engine runs at etc etc etc........
