HeavyObject
Thread starter- Joined
- Aug 26, 2007
- 82
Need to pull the flywheel to get the ring gear replaced and this happened. It's a cast crank and it shattered when I rapped the puller with a hammer in an attempt to get it to pop loose. No the nut was not on the crank when I was trying to pull the flywheel. Now what to do? Grind it flat and risk mushrooming the crank or find another nut and make a spacer to ride on that then index the puller to that.... Suggestions???
