bringing back color on boat
kennywaynem
I bought a bass boat the top half is faded is supposed to be red but its orange. Can I get the red back by applying something?
jbcurt00
Is it metal flake gelcoat?
Can you feel the flakes sticking up thru the gelcoat?
Pix would be a great help
kennywaynem
Im having problems putting the picture on here but it is metal flake but I really cant feel it by rubbing my hand over it
zool
What you have is clear gelcoat, over flake, over colored gel....actually, originally in the mold, its the opposite, but that's a different discussion. There isn't that much clear between the surface and the flake edges. Gelcoat flake is usually large. To remove the hazing, you have to cut into that thin layer, but you can try it a little aat a time. You can try a cutting and buffing compound 1st, to remove only the surface haze..see how that goes. If you need to remove more, then wet sanding is the next option, with progressively higher grits up to 1500. Once the flake starts poking thru, like JB was asking, its build primer, and paint
zool
Open a free photobucket account, upload your pics, then paste the img code in the text here...that's the way to go.
kennywaynem
Ok ill try tomorrow but if it looks like a major project it may stay orange haha I work alot of hours and the fish are biting cant sit on the bank till someone else does it for me maybe a winter project
zool
That works too, just bleed them over the sides to make it red where you see it...and maybe one day, orange will be the next red :D
