Re: Bringing it back to life...
OK, got the money pit out this weekend, and I am almost positive I have it figured out. First, it is a 3.0 OMC engine with the silver/grey outdrive (1986) and it is not an ignition problem, it is a fuel problem. The spark plugs are getting spark, and the engine is firing but does not stay firing. After further examination, I am pretty sure it is the fuel pump, but let me get your opinions on the matter. The over-fill tube from the carb is all clogged with gelled gas (I assume that's what it is, it's green) right near the carb. According to the manual I have, this would be due to a bad filter screen inside the pump or something like that? Anyways, disconnected all the hoses and the overfill hose is caked with the stuff, and it looks like it has been an ongoing problem, cause there is a lot of gel and the tube is clogged. So, my plan is to replace the fuel pump and overfill tube, but I need to wait til I have time to handle it.
So, what do yall think? Does it sound like I have it figured out right? I checked the ignition system, replaced plugs (definitely needed but not the problem) and battery cables, they were going as well. Checked spark going into the distributer and that was all working, and like I said, the engine was firing just not running. Oh, and I will also probably have to replace the fuel line from the gas tank, it is looking bad.
Thoughts? Suggestions?
