Brining back that old shine...Need HELP!!
YamahaRacer447
I bought a used 14ft flat bottom aluminum jon boat and need some advice on getting her a new pain job. I want to repaint the outside with a dark green but i hear aluminum is a pain to paint and you need etching primer and other crazy stuff. Is it harder than just sanding it down, putting a primer, then one or two coats of paint on? Let me know cause i am losttt...:confused:
tmcalavy
Re: Brining back that old shine...Need HELP!!
Is is really cruddy and corroded, or is there some old paint on the hull? If it's really trashed, drag it to a shop and have it soda-blasted...then take it home and hit it with some primer...self-etching primer costs about $6 a can at auto parts stores. Or just get some rustoleum primer and top coat and paint it using the roll and tip method...you roll it on with a closed-cell foam, thin-nap roller, then barely skim it with a brush. Makes a good finish and only costs you some time. Search this forum for roll and tip and you'll find threads on how to do it. If it has paint on it, you can rough it up a little with steel wool or light sand paper and the top/color paint will stick okay. If you want camo, Stuff-mart has a stencil and the camo colors in rattle cans. You could probably paint a john boat for less than $50 with rattle-can paint. Here's a couple pix of my recent repaint of the Texas Maid. I repainted the topside deck, gunwhales and splashwell with Petit Easypoxy using the roll and tip method...it's oil-based paint, so kinda messy and requires mineral spirits for clean up. Lots of folks, including Tashasdaddy, have real good luck with Rustoleum. What you use depends on how much you want to spend for paint. Not hard to do though.
YamahaRacer447
Looks good man... Its not really beat up the paint is in-tact excluding the normal fading and scratches but its my winter project so i figured what the hell... I dont wanna halfass it but not trying to spend a fortune either. Thanks for the input just looking for diffrent methods that i could use to paint this thing..
fixb52s
I just did up a 10ft jon boat. It was unpainted, so I got some of that etching bare aluminum wheel cleaner that you spray on and hose off. I did some scrubbing with a scotchbite pad (wear gloves) prior to hosing it off. It cleaned the metal up good and gave it a slight etch. I then primed it with Rustoleum metal primer and folowed that with their satin olive drab paint (all spray paint). I did the bottom with a can of Plasti Kote roll on truck bedliner from the auto parts store with no primer. So far, it is holding up very well, having it out a few times on the lake.
I figured the boat was cheap, and I did it low buck. If I do scrape it up a little, some touch up paint will just fix that. This is just my fish catching machine, not a showpiece.​
