British Seagull - Gas/Oil mix ratio
bostonwhalermontauk1965
Hey Guys:
I have an old Seagull outboard - was wondering what the Horsepower was and gas / oil mix - and do i have to change water pump impeller in this one too? model # is WPCL 1132EO Thanks in advance for any help!!!! Paul
keith-uk
Re: British Seagull - Gas/Oil mix ratio
Your Seagull was Manufactured on May 1970, this model was Manufactured from 1967 to 1973, so its a late one.
Its a Century, with Clutch, 4 to 4.5hp, Gear Oil is SAE or EP 140 and Fuel Ratio should be 10:1, or 1 gal unleaded to 12.8 oz oil.
But the motor may have been converted to 25:1, so you will need to look at the needle in the carb.
As for the impeller, if it runs and pumps water then, no need to.
Try: http://www.saving-old-seagulls.co.uk/index.html for more information.
Hope this helps.
truckintyler
the water passages in the cylinder get very rusty and can cause water not to flow. mine was packed solid with rust
