Year is 1969 Johnson 20 hp. I was working on the ignition system (new coils, points, condensers, wires) while rotating the flywheel, I heard some hissing by the cylinder head. Turns out it was the top spark plug. Went to pull it out, and the threads came with it.
Bought the new head
Then pulled the old one off, and found a slight, but noticeable scratch in the bottom cylinder.
Compression prior to breakage was 80psi even in both. Ran and sounded great. A little hard to start, and took a pretty strong arm to pull, otherwise fine.
Did I just waste $20 on a cylinder head, for a motor that wont last long?
As long as the head is off, should I clean pistons or anything?
Old gasket came off in one piece, should I buy a new one anyway?
Seirra make them? Johnson number is 306163, but I cant find it on iboats.
Bought the new head
