When replacing one of the pistons on my 1992 Force 150 hp - snapped one of the connecting rod small end bearing cages in two pieces. Of the 7 bearings captured in the cage, 5 are in one piece, 1 is in the other, and one is in between where the broken spot was. Clean break, edges fit back together ok.
Got it back together and the connecting rod cap reinstalled with exact alignment (when dragging a pointy object over the two seams it doesn't catch).
My question is: Should I replace the cage with a new one, or once it is installed with good alignment is it ok? New one requires purchase of a whole set - including both halves of the cages and the 16 bearings, runs something like $137.
Thanks,
Thanks,
