turtle1173
Thread starter- Joined
- Nov 29, 2001
- 437
Re: Broken Bolt on Exhaust Plate
Hello all,<br /><br /> I just wanted to keep you all updated a bit and perhaps provide some more information. I haven't done anything with my situation yet because it's been raining for the past couple days.<br /><br /> The exhaust plate is probably 3 inches wide, taking into consideration the outer plate, gasket, inner plate, and gasket. So these bolts are fairly long. If there are no threads in the plate, how effective is heat going to be? Also how effective will the PB Blaster be? Is any PB blaster even getting to the corroded threads?<br /><br /> If I get the plate off, even with a busted bolt, there will still be a couple inches sticking out from the powerhead.<br /><br />OB, the bolt is slightly below flush with the exhaust plate. I can't take it off yet because of that one bolt on the bottom.<br /><br /> I would prefer not to break the bottom bolt head off but let me ask you this: If it does break off, won't that just allow the plates to come off and then actually give me better access to the rest of the bolt for heat or PB Blaster?<br /><br />Just wondering....<br /><br />Shane
