How is the best way to get broken bolts out of the block? I've got them drill about half the diameter of the bolt now in the center went all the way past the bolt maybe about 1/16 past sprayed WD-40 let them soak and tried an easy out. Should I put a defined small amount of heat to them? I've got 4 out of 10 broke. 1986 60 hp merc.
