Broken bracket
guyren
Is it possible to repair this? I don't think I could weld this type of metal so what other options do I have?
rick_l
Re: Broken bracket
I believe that probably could be welded by someone who knows how to weld alum. If not I noticed a bracket with a screw hoe just below. Is it possible to run a brace up to this and mount it thru the brace.
F_R
Re: Broken bracket
Aluminum is weldable by anyone with the proper equipment and experience. Needless to say, you will have to remove the part first.
Chris1956
Re: Broken bracket
Guy, Generally the transom brackets are forged aluminum. A good welder should be consulted to see if he can fix it, but since it is forged, it should have a better chance.
guyren
Re: Broken bracket
Thanks for the great ideas. I did not realize this was aluminum.
