Broken drain/vent on 1987 OMC Cobra
Kim1349
When winterizing last fall, we pulled what appeared to be a drain plug from the port side of the Outdrive. This is on the middle unit, not the gimbal and not the lower unit. It is mid casting. If you look at the other side there is a OMC logo and this drain/vent is on the opposite side but in the same location as the logo.
When we screwed it out, water came out. When we went to put it back it, it's like the threads have disapeared. All there is now is a plastic circle about 1/16 thick and no threads.
I find nothing anywhere on the drawings or in the manual showing anything like this on the side there. I am not talking about the oil fill/drain now that is elsewhere.
Can someone please tell me what this is and how to fix it?
a70eliminator
Re: Broken drain/vent on 1987 OMC Cobra
Plug the hole with a rubber expansion plug. Or remove the drive and fish out the threaded nut that dropped when you unscrewed the bolt and is now laying useless in the bottom of the cavity.
Use the search option and you'll get about a 100 hits on that very same topic.
HT32BSX115
Howdy,
You have just joined " I removed the NEVER-REMOVE plug " club!
This usually happens when you don't have a service manual and you're attempting to service the unit without having all the info to do it!
Relax you're among friends! (although I never did remove mine!!)
It's also not the end of the world either......But you do have to remove the drive to get into that area to reinstall the nut on the other side.
I don't think anyone really knows why that hole is there. Most of them are covered by the OMC logo. The logo on a lot of them has fallen off and the screw driver blade slot is just too tempting for most people unfamiliar with the Cobra to leave alone!!
Anyway, pull the drive and replace the screw/nut and don't do it again!
Get yourself the correct OEM manual so you don't join the "I filled the drive with oil like a Mercruiser" club and destroy it in the process!
Cheers,
Rick
boatguya1
That second club costs alot more to join. Most I know joined it the filled the cobra like I did my Johnson/evinrude outboard lower unit/ what do you mean I did it wrong and caused all that damage route. I had one cust a few years ago did it to both drives of a twin he just bought.
James
HT32BSX115
Yeah
It happened to my King Cobra.....TWICE!
Only it was a "Dealer" that did it both times!!!(different dealer though)
Well the first time the dealer didn't bother to put oil in it all, The second dealer filled it like a Merc. and it destroyed the upper.
Both dealers replaced the drive both times without my brother (the previous owner) having to "Lawyer-up"......when I got the boat the drive had less than 200 hrs on it! I thought I got a pretty good deal on that one!!
I was a little disillusioned with Four Winns dealers after that though.......
I change my own engine and drive oil .
Kim1349
Ok. Many thanks for the replies. Oh, and I did search and found nothing. I must not have worded it correctly. Oh well.
Now you have me wondering what your talking about filling it like a Merc? And yes I will get a book for it, thanks!
:eek:
HT32BSX115
Yes, you need to get the correct OEM service manual before you starting doing "things" to it!
"Filling it like a Merc" (from the drain) will trap a rather large bubble of air in the drive that will eventually make it to the top, uncovering the upper gears and bearings.
They'll self destruct shortly after that and take out the rest of the drive.
It's not pretty.....it IS expensive.
The OMC service manual outlines the correct procedure to fill the drive.
Cheers,
Rick
Lou C
Cheers,
Rick
If you need to change the drive oil, and can't find a factory manual quick enough.....
go over to
www.crowleymarine.com
look in product support....OMC drives and you will see the Cobra oil change procedure (factory pages and pics) as well as the R+R prodecure....which is what you need to do to fix the screw you removed.....Mine doesn't have the OMC badge over it....but I resisted any urge to touch it....and the funny thing is that the OMC shop manual good as it is, doesn't say a thing about this, it is only referenced in some of the parts manuals that you can see on crowley marine and doug russell marine....so fix it and leave it alone....
grooter
I have 1990 donzi with this same issue..... When winterizing the unit the antifreeze was leaking around it so I tried to loosen if and it feel apart!!!! If I can get the backer nut fished out I can put in a expansion plug and be good to go?????
Lou C
No you need to fix it the right way. If that plug pops out at speed you will lose all of your cooling water out that hole and overheat the boat in a heartbeat. Pull the drive, do it right and do the drive maintenance at the same time (supposed to be done yearly)
grooter
Where does one get the correct parts seeing how this isn't listed in any of the manuals....??
HT32BSX115
Howdy, Welcome Aboard!
First of all, it's really best to start a new thread even though this one speaks to the subject directly. The Forum "rules" are quite specific.
From above:
Help Tip: If you have a question that has not been answered to your satisfaction in the archives, it is always best to start a new thread of your own. By starting your own thread, you will receive the maximum number of views by forum members.
Below are some additional forum policies in hopes of all iboats members will follow, Thank you.
1. Please do not reply to old topics or hijack existing topics. Old topics of a technical nature are like a library book, Please do not write in them.
2. Old topics should be considered archives and used for reference only. Please do not reply to them.
3. Do not take over someone else�s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
4. If you have a question for the original poster (OP) and the topic is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old topic.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it�s posted at the end of someone else�s topic. And those answers will be specific to your particular issue.
6. Please do not post to topics that have been inactive for more than 3 months unless you are the original poster. We have very active forums and any topic that remains inactive for that long should be considered "dead". It is especially confusing when there is an entirely new question posted to an old topic.
7. Posting at the end of any topic is considered to be hijacking the original posters topic which in turn subjects the topic to be closed if it continues to happen thus not making it fair to the original poster in the future had for some reason he/she needed to return for additional information or provide an update of the problem solved which is always welcomed within a reasonable amount of time frame.
8. Please note that you should see a red banner pop up near the bottom of each inactive topic asking you not to reply to old topics. The Red banner will read: Please note this topic has been inactive for 90 days. For the best results, please start a new topic.
Thank you all in advance for doing your part in helping iboats run a smooth ship.
Additional forum rules linked below.
http://forums.iboats.com/forum-rules-guidelines-405/
It's suggested to remove the drive and find the "backer" nut because it could be pumped into the cooling system and plug the t-stat, oil cooler or supply hose etc.....
You can use just about anything to back-up that "screw" (like a small ss plate with a self locking nut) if you cannot find the original one, but it might have gotten into the hose that goes to the oil/PS cooler and into the T-stat housing. If it's lodged in the hose, it could reduce total cooling water flow and cause an overheat.....
You may not be able to actually buy the part. Most of those parts were scarfed up many years ago...... (OMC has been gone for more than 15 years.......)
Regards,
Rick
