Broken oil pan bolt removal
metsfan3197843
in the process of changing out my rusted out oil pan one of the bolt heads sheared off like butter. Tried vise grips. Any suggestions???
thanks
achris
More fish than mountain goat
If there's enough sticking out, once the sump is off, weld a bit of steel to the stud and unscrew it...
Smack it with a hammer, then use the vicegrips
metsfan3197843
The hammer was the ticket, thanks. A little embaresed I didn’t try that in the first place🙃
when you work on old broken things as a hobby long enough..... you acquire a bit of knowledge on freeing up things.
