my engine began to have idle problems late this summer, I did a compression ceack and found low numbers on one cylinder.
1983 reman 115 flat back from OBR 2 yrs old this past spring.
no vro. max timing retared 2 degrees as per OBR
Just broke it down by removing the heads, intake, inspection covers and exhaust plates and here is what i found.
head gagkets looked ok
rings in the 2 cylinders on one side of the engine are broken on the exhaust side, standing at back of boat looking towards the front, the RIGHT side of engine where all the carb linkage and shift linkage is
milky oil in the exhaust chest up top near the bad top cylinder and a little on the opposite side on the top, nothing towards the bottom.
plugs are clean, piston tops all look the same all have black carbon.
my questions are is this a result of clogged carbs? both of them clogged.. it runs well at high spped and has over sized high speed jets per the OBR factory. just idles like crap.
water intrusion from some where or both?
