Okay everyone, another question!
I purchased a Glastron boat 3 weeks ago (my first ever boat and thought I did a pretty good job checking it over!). I have used it twice (each time for about 3 hours). On the second outing the starter motor would spin up but not turn the engine over. I assumed it was a defective starter motor.
When I got home I went to remove the starter motor and I found an unusual problem. I fear this is an engine out job to fix, but wanted to ask your advise.
The engine is a 1991 4.3L V6 Mercruiser 262CID.
The starter motor bolts to the engine with 2 long (approx 4") bolts in an offset pattern. The bolt nearest the engine is fine, but the bolt furthest from the engine is missing
. The reason its missing is that the engine casting that should go over the bolt hole and have a tapped hole in it for the bolt to enter, has been broken off at some time!! The starter motor was held in place by one bolt, the casting of the starter motor could not take the twisting force when the starter motor turns and has broken the starter motor casing around the bolt hole, this has caused the gears on the flywheel and the starter motor to no longer mesh!
I have purchased a mercruiser remanufactured starter motor, but do not want to mount it with only 1 bolt (as it will just break again). I have been trying to work out the correct position of the starter motor (as it can pivot a long way on the one bolt) to get correct gear mesh, but I suspect that without removing the engine from the boat and then removing the stern drive to be able to see the flywheel and starter gear, I will not be able to get the starter motor correctly aligned.
I am going to try and build up a new casting mount (using my arc welder) but again it will be very difficult to correctly drill and tap the hole without removing the motor (which I don't want to do!).
Is this a common problem on the Mercruiser 4.3L engine, or has a Gorilla owned this boat in the past?
Any suggestion on how to align the starter motor, or fabricate a new mount for the second bolt hole would be appreciated!!
And I will appreciate it even more if it doesn't involve removing the engine!!
My garage roof is too low to get an engine hoist in, plus I don't own an engine hoist that will go high enough to lift the engine out (probably needs to be a chain hoist!!).
Gary
Gary
