Broken throttle linkage
hockeyfann
this passed weekend I was running my 1957 10 hp johnson seahorse and then something snapped because I overturned the throttle lever on the tiller. Now the throttle shaft gears are unaligned with #41 on the diagram below(go to pg 10). So my question is what parts need to be replaced in the diagram. Thanks
here is the diagram http://www.marineengine.com/parts/vi...7702000001.htm
AlTn
Re: Broken throttle linkage
try Page 9, part # 33..may have broken one of the ears off that plastic pin...
hockeyfann
Ok i just looked at it and i think it might be #75 101 or 72 on pg 10 however if part #41 and 72 interlink i am almost positive that stop screw in 72 is the problem. Let me know what you think.
AlTn
hard to say w/o seeing it...you're gonna have to dissamble it back to the gears that aren't aligned anyway so it should be clear what's wrong when you get there
