Maddoxsdaddy
Thread starter- Joined
- Sep 22, 2008
- 222
Re: Building a 350 Vortec motor
I will double check all of that. thanks! I'm using NAPA's machine shop. They've done really good work for some friends so i trust what they're doing.
Pay attention to Johns Advice on the Head modifications for the increased cam lift... Cut the tops of the guides, install screw in studs, maybe guide-plates and drill the push-rod tubes for clearance. Add a set of roller rockers and you are off and running. You should have around 330hp and over 400 ft lbs of torque.
If you switch to guide-plates you need new hardened push-rods. If you don't use guide-plates you need the proper self aligning rocker arms. if you are really trying to not spend money you can use stock type rockers.
Also you might need to clearance the block a little to use the double roller timing chain, they hit on the backside of the top gear.
