Reserector_
Chief Petty Officer" & 2021 Splash of the Year Win
- Joined
- Oct 15, 2019
- 654
Sure it was pouring rain, but I need failsafe reminder system. Any ideas?
forums.iboats.com
put a tag on the truck keys with the following:but I need failsafe reminder system. Any ideas?
If you go that route check out a arduino microchip. They are not expensive and you can program it to do just about anything you can think of. I bought one a few years back to spend time and teach my son about building things. They are pretty cool just to mess around with i was contemplating what I could use it for on my boat.Here's an idea I have been brainstorming:
Use the resistance signal from the tilt/trim sensor to trigger a pair of switches. Probably using NPN transisters or and op amp with a pair of potentiometers to choose the trigger points.
One would activate a light if the drive is UP (out of the water) and the key is switched ON.
The other would activate a light if the drive is DOWN (low enough to drag when on the trailer) and the key is switched OFF.
Granted, there will be times when I will shut the engine off when anchored, or just stopped, but I will be able to adjust the trigger to a point where it only warns me if the drive is in the range that would hit the ground while on the trailer. Would be easy to raise it a bit to make the light go out. Small inconvenience compared to killing the skeg.
Same goes for the UP warning; Only if the drive is high enough to suck wind if I start the engine. Even with muffs, it's not good to start it with it fully raised.
Your thoughts before I pursue the electronic part of this?
Awesome Job! Also the benefit of knowing that you have a safe boat for your family!!!! For a whole lot cheaper than a new boat, not to mention the satisfaction that you built itI recently added up my expenditures on this project. I counted materials that could only be used on this project, special tools that I doubt I will ever use on another boat, parts, and consumables.
Consumables are items like brushes, solvents, gloves, tyvek suit, etc.
I did not include parts that I ordered wrong (and plan to resell), excess quantities that can be used on other projects, nor service parts that I bought for stock.
I did include the stereo and the addition of disc trailer brakes. Those two things were not technically necessary to get the boat going. Combined, they are around $500.00
Not counting my time, of course, the "all-in" figure (rounded up slightly) is.... $6,500.
My whole family having fun together.... priceless.
Nice job ole man!As I worked through the project I kept discovering more things that were missing. This thing was little more than the two outer fiberglass shells, a trailer, and rebuilfable drive components.
All in all, I think I faired pretty well on cost. I think I did well on time as well. I stuck with it, but didn't burn out.
I still don't know what snapped in my brain to make me want to do this. I guess it was the challenge, but to be honest, I just didn't know how to get this derelict off of my property. So...problem solved, eh?
