chevymaher
- Joined
- Mar 29, 2017
- 2,937
This year is strange for the heat. My boat been sitting for the same reason. It is even hot as H@ll when it is raining.
Hahahahaha!Great for foaming the hulls though . . .![]()
I was thinking about that the other day while in the garage. I foamed my hull in the winter and had to burn kerosene and use my heat pump to get my garage up to 89F so I could pour foam. Now it easily gets up over that on it's own.Great for foaming the hulls though . . .![]()
Trip Hazard and Chief Mood Improver.What is the cat's job in all of this?![]()
It's Tuffer's boat. I just maintain it.![]()
There’s two cracks there right ? On below head and one above pan rail ?I got my materials ordered to fix my 7 1/2" long crack. $355.74 for everything including tax and shipping. That includes pins, drill bits, tap, spot facing tool, cutting fluid and special thread sealant.
They are also sending a thumb drive with all their videos along with written instructions.
Yes, there are two cracks. I repaired the lower one by brazing while I had the engine torn down. You have to put a ton of heat into a block to do that.There’s two cracks there right ? On below head and one above pan rail ?
Had good luck with this method on mill casting at one of my old jobs years ago was a permanent repair
