EricJRW
Thread starter- Joined
- Feb 3, 2010
- 488
My 50HP 2-cycle Evinrude really puts out a lot of noise... So much so that the aft seats are not a fun place to sit while underway, yet those are the best seats in the house (comfort and under the bimini). In the grand scheme of things, I don't think the motor is louder than it should be, it's just that the proximity to the aft seats is bad.
So I came up with the idea to build a shroud... Basically a four-sided box with walls on the sides and in front of the engine (between the engine and the aft seats) and fit it with a hinged top.
The height will be such that I can tilt the motor up fully without having to lift the lid on the box, but the lid is hinged (at the front/fore edge) to allow access to the motor.
It will be 51" wide, about 28" front to back, and about 30" high. I can get all this out of a single sheet of plywood IF the front is only 20" high (meaning there will be a 10" gap at the bottom, directly behind the rail and aft seat, which I figure will also absorb/reflect a lot of the sound).
I could eliminate the gap if I wanted to lift the lid when I raised the motor, but since we beach the boat every once in a while, I wanted to be able to keep the top of the box flat for a place to tie a tube or other light objects.
Since I'm still not 100% on the height, I decided to build a prototype out of exterior grade plywood instead of the more expensive marine grade. I figure if I get one season out of it, and prove the concept, I will build the next one out of marine grade, seal it, and cover it with carpet.
So what do you think? Is there anything else I should consider?
Thanks for reading,
Eric
PS. I've attached two pictures of the stern of the boat. The shroud will basically be the size of the aluminum deck, i.e. it will fit between the two carpeted areas and go from the back rail to the back of the boat. The height will be to the top-most rail (I think a good height for stowage too). If I went to the lower rail, the gap at the bottom would not be required, but then the lid would need to lifted to tilt the motor all the way up (the boat is kept out the water at our dock, so tilting is not strictly required to dock, just to beach).
Thanks for reading,
Eric
