Quinc
Thread starter- Joined
- Feb 11, 2018
- 15
I mostly just read the forums, but figured some of you might get a kick out of this. Also any tips on what to paint the bottom of the hull with to reduce friction?
Built this over the winter with my 8 year old. He took every nut and bolt off the ski and did the fiberglass! So please give him a like and sub on youtube.
Ski ready to ride weight is 226lbs. Battery weighs 35 pounds! Once I figure out if I want to stay with sprockets or swap to coupler I will shave some weight off or maybe go to aluminum engine mount. Also thinking I can cut out the hood liner for a few lbs.
Specs:
Ski 1986 300sx
Skat 16 impeller
Motor sprocket 14T Driveshaft sprocket 10T (Did this so I could adjust rpm/torque with sprockets)
Still trying to Figuring out the rpms Vs Torque for a jetski.. I also have a Skat 15 and PJS 17 impeller to try. In the video I think the top speed was around 15mph.
Cool thing about it is you can adjust 3 separate speed settings so when my 4 year old rides it I can keep the speed around 10mph for him.
If it turns out to be awesome I will probably try the 8000w motor next.
Specs:
- QS-120 motor 2000w / Maximum Torque: 20N.m to 49.6N.m. (more info on motor and controller specs)
- Votol em-100 controller
- 72v lithium battery capable of 800amp peak power.
- ANT 300a bms
Ski 1986 300sx
Skat 16 impeller
