rivertripp
Thread starter- Joined
- May 5, 2010
- 41
i have a 1980 75 hp Evinrude and the motor runs great, but when put into neutral or idle forward the motor will run for about ten to twenty min. the die out. When I got to prime the bulb in the fuel line, it has not pressure to it and I have to squeeze it about 5-10 times. Even after priming it though the bulb does not get pressurized. When my mechanic worked on it awhile back he used his fuel line and fuel tank, and everything worked great so we know the fuel pump and fuel pump lines work good and have no leaks. Any suggestions on what might be going on and what to do about it?
