Buna-n Orings ok to use for Captains Call actuator rod???
PSDfreak
As I have posted before, I need to replace the small o-rings that seal the water from coming out of the exhaust pipes at the actuator opening for the captains call exhaust solenoid. There are two small o-rings on the actuator rod that goes into the pipe which the flapper screws onto.
I went down to my local autoparts store and found what looks to be the right size orings so I got them. They are made out of "Buna-n" which is nitrile as I understand. My concern is, will this material be ok to use? They are black o-rings...The original o-rings I pulled are orange. I would imagine that with water going through the exhaust pipes it doesnt get TOO terribly hot.
Any words of wisdom?
Thanks,
Casey
PSDfreak
Re: Buna-n Orings ok to use for Captains Call actuator rod???
Doing some further looking around online it seems like I am seeing that Buna-N orings are good for 250-300*F. Now the question...How hot do the pipes get with fresh water running through them??
Limited-Time
The orange o-rings may be silicone which holds a much higher temp rating than Buna.
Ayuh,.... Try it,....
Worst Case would be having to do it Again,..... With the Right parts....
