Bunk carpet?
jonny rotten
Want to replace mine.Is it just indoor-outdoor carpet or something else?
NYBo
Re: Bunk carpet?
Indoor-outdoor carpet will work just fine.
Texasmark
Re: Bunk carpet?
You want a closed cell carpet so that it will dry out quickly with a rot resistant backing...substance that holds it all together. If stored in the sun, then Marine Carpets have sun blockers that I/O carpet do not/may not have.
HTH,
Mark
642mx
Re: Bunk carpet?
In the Fall of '10, I replaced my carpet with indoor/outdoor carpet from Home Depot... At the end of this year, it started to rot and fall apart.
I just ordered real marine grade carpet from my local boating shop. Sure its more expensive, but I really don't like to recarpet my bunks every year. Live and learn I guess. Some might have good luck with it regular carpet, but we boat a lot. We went out 34 consecutive weekends in 2011. :)
fishrdan
Re: Bunk carpet?
Weird, I used cheap Home Depot carpet on my old boat/trailer and the bunk carpet lasted 8-10 years, until I got rid of the boat. The interior carpet (same stuff) went to hell in a handbag within 2-3 years though..... The bunk carpet was hardly ever exposed to direct sun light, so I'm guessing that's why it lasted so long.
Texasmark
Re: Bunk carpet?
Agree!
scrit9mm
Re: Bunk carpet?
I had the same experience fishrdan. My first re-do on my first boat I used the grey outdoor carpet from Lowes, bunks lasted 5 yrs until I sold the boat but the interior was starting to get flakey.
Just put that same carpet on the bunks of my 14' project trailer. I would not recomend putting it in your boat if you want it to look very nice.
OllieC
Re: Bunk carpet?
Dumb question - Could you use composite decking wood (you know the plastic/sawdust) as bunks?
Silver Eagle
Master Chief Petty Officer
Re: Bunk carpet?
It's very important to check the mounting bolts bewfore you rercarpet. I saw on that was loose and then I found out that most of them needed to be replaced. So I replaced the wood bolts and carpet at the same time. The trailer is an 2006 .I also covered every thing with that new plastic coverings.
sschefer
Re: Bunk carpet?
More than anything you want something that drains well. Keeping moisture up against the hull is not a good thing. I buy the Marine Bunk Carpet at West Marine. I've never kept a boat around long enough for it to fail though so I can't attest to that.
catfishr1
Re: Bunk carpet?
As for me, I use marine grade bunk carpet for bunks & guide ons. Premium marine grade carpet for floor. For me extra expenses offset by extra yrs of service. My buddy uses a good grade of indoor outdoor & has been very happy.;)
