Bunk Slicks?
gpfishingdude
Does anybody know if the wrap around bunk slicks that go over carpet and fasten from the bottom work or are they too flimsy and a waste of time to install. I would like to install something on the front third of the bunks to give it just a little initiative to slide back when launching. I don't plan on adding anything that is 1/2" thick that might dent the pontoons or make it sit uneven enough to wear on them. On second thought I think I will try some silicon spray first.
junkman41
Re: Bunk Slicks?
to launch, I put the trailer farther back in the water to wear the pontoon floats right off. that works great for me, hope this helps you
Jack
Silver Eagle
Master Chief Petty Officer
Re: Bunk Slicks?
I put them on my 24 ft trailer, Couldn't tell any difference. I backed the trailer up to the water's edge Got the boards wet and I unlooked the boat and it just sat there. So I used the boat the normal way, I backed to boat until it floated off. It's a steep ramp too. Cost me $250.00 They look good though.
gpfishingdude
Re: Bunk Slicks?
Thanks! Silver Eagle, I was just thinking about trying the cheap ones that only cost about $40 for ten pieces and just installing them up near the front where the boat tends to want to cling a little to the trailer. Like you said the back wants to float off pretty easily because it is down in the water. I am learning how to get the truck in 4wheel drive for when I need it the next time. We had a little trouble the last time because of the low water levels at all of the ramps around here right now. Like the wife says all the time -I should read the instructions before doing things, I learned a lot buy reading the owners manual for the truck last night.
BobGinCO
Re: Bunk Slicks?
I read somewhere, that they are just spraying silicone lube on the bunks, and they become a lot more slippery.
