Re: Burnt piston on 150 black max
Sounds logical but the other 5 cylinders look ok- plenty of oil. Could it be a trigger or stator problem because it also seems to have to build up rpm,s before it takes off? I can hear it picking up cylinders as it speeds up.(by that I mean it will suddenly kick in on one or two of the cylinders as though it was not firing on them before)-but it has good spark at idle on all 6 cylinders and did have 120 psi compression on all cyl,s before the piston burned. I have read alot of other posts, both here and on other forums of others having similar problems with these motors. Just trying to cover all the bases and I feel the problems are related.
