Burnt rod bearing
inlet
Re: Burnt rod bearing
SORRY HIT A WRONG KEY<br />Question two : yes prelubed through distributer channel with a drill, while turning motor over with starter.
rabidfish
I'm with rodbolt... not enough clearance, or improperly assembled.<br /><br />A little grit will cause damage but not complete overheat and bearing failure. it might score and lose oil pressure, but it wont turn blue
rodbolt
side wear on the bearings usually indicates a bent connecting rod. were the rods rebuilt at the overhaual? its possible the machine shop misalined the rod big end bore to small end bore alinment. usually a plastigauge strip will find that but not always.<br /> usually if the tabs are not lined up it will flatten the tabs and reduce the bearing clearence at the tab area to zero. a spun bearing will turn the rod blue as well where the bearing was spinning against the rod.<br /> either way by now the rod is history most likly.<br /> its also possible that the rod was not correctly placed on the piston. there is a fixture for it but its amazing the amount of people I have seen assemble them by eyeball method. my peepers are not that calibrated so I always used the fixture or sent them to a trusted machine shop.pics of the rod,crank and bearing would be great. sounds like your tech is looking hard for a failure cause . keep us posted
Buttanic
Misplaced rod cap maybe. Look for another rod journal that may be showing signs of mis-alignment.
LubeDude
Originally posted by warren peas:<br /> SORRY HIT A WRONG KEY<br />Question two : yes prelubed through distributer channel with a drill, while turning motor over with starter.
This was fine as long as:<br /><br />The oil preasure was allowed to build first and you had oil coming out of "all" the push rods before you started to turn the engine over. And even then you should just rotate the assembly about a quarter turn and then prim again. Do this about four times and thats good. I think maybe the priming procedure was at fault. Many do not prime long enough. Usually it will knock out a main though. If the rod was bent, I would think that the engine would have become tight as you assembled it. Ill tell you from experience that it doesnt take much. I was assembling an engine one time and when I torqued one of the Rod caps down, it froze the engine. I removed the cap and could see a shiney spot on the bearing. I looked at the crank and it was good, and then I took the bearing out of the rod and under the bearing was a tinny little nick, I mean you could barely feel it. I smoothed it off with some emery paper and things went fine from there. It was a budget rebuild so we didnt resize the rods which I normally do.
inlet
Thanks all. <br />Lubedude, just walked down to the shop, Mechanic sees me coming says "you been on the internet again haven't you" Good chuckle, Long story short his prelube procedure was exactly as you described it should be. <br />Hoping to finish reassembly tomorrow, put in boat Saturday, run test over weekend. Will update on result.
AaronG
Its tough to put a rod bearing in wrong. I bet it was the wrong one in the right box or mismanufactured or something of the sort.
