Buss Fuse Help
bumrunner
I just blew an inline buss fuse from the main power line from the battery to the instrument panel. The fuse reads "Buss AGC 5" and "35 V." I'm assuming that the "ACG 5" stands for 5 amps, but it doesn't say "Amps" on the fuse like the new one's do. Am I correct in assuming this? Also, the closest thing I could find was an ACG 5 Amp 125 Volt. Will this suffice as a replacement or should I be worried about frying my electronics. This is an older boat if that helps at all. Thanks in advance!:confused:
Silvertip
Honorary Supreme Mariner
Re: Buss Fuse Help
Voltage is not a concern. 5A is 5 amps.
bumrunner
Re: Buss Fuse Help
Thank you about the volts, it doesn't say 5a, it just says "Buss AGC5" so I'm hoping this is 5 amps, would I be correct?
bumrunner
Re: Buss Fuse Help
Thank you all for your help, very much appreciated.
