Re: butterflys won't open on carb
troy;hope i can exp.this type "A" carb correctly,electric choke (flapper)closes when choke button is depressed,opens when released.when choke lever (manuel)is pulled up it chokes carb and will keep ckoking untill manualy pushed down,it literally overrides the elect. choke..there is no butterfly in the carb for choking.the cam you mention is the trottle stop lever that controls the trottle shutter.maybe its your trottre pick up that needs some adj.. hope this helps ,good luck...
