Buying a used lower....need same gear ratio??
clattin
So I destroyed my prop the other day and am worried that the prop shaft is also bent. Thought I'd try to pick up a used lower to pop on and minimize my downtime and I can deal with a bent prop shaft over the off season.
My current boat is a Mercruiser GM 305, Alpha 1/Gen 1 with the 1.5 gear ratio. Do I need to find a used lower that is also from a 1.5 gear ratio or will any Alpha 1/Gen 1 lower work?
Thanks!
Chris
clattin
Thanks! I assume I should go ahead and replace the water pump/impeller. Should I just replace the whole water pump or just the impeller kit? Anything else I should do before I bolt it back up?
Bt Doctur
You wont know untill you open it up fir inspection/replacement
