nathanhooper
Thread starter- Joined
- Apr 21, 2010
- 176
Well as if I did not need another thing to deal with, low and behold I decide to check the valve to make sure it was ok and found out it was not. Took the cover off, pulled, and pulled the cover with spring attached, finally got the spring out, albeit it is stretched now. Where it is located it is hard to see, but when you put a mirror down there you can see the valve stuck in there, I assume that is. It seems soft, like plastic when stuck with a small screwdriver.
My question is, how do I get it out? Where it is located I cannot really get anything in there to pry it out. I was thinking of drilling a small hole in the cowling to stick a screwdriver through and work it out, but is there something else that will work? Has anyone had this problem before?
