bob johnson
- Joined
- Feb 25, 2009
- 4,306
My 1995 115 Johnson looper has been acting up since December.. Originally I thought it might be water in the gas, then I thought it might be the gearcase...then after posting here I had thought that it might have been a leaking t-stat housing allowing water to run down onto the spark plug and short...BUT the issue really never left . it was sporatic which made it worse... the motor would buck...like it was missing badly...well the motor finally died on my sunday while fishing for stripers( finally got out after them and then I have this issue) got a friendly tow back...motor cranks hard...but wouldn't start...so I checked and had no spark. Went right to my mechanic, who by the way hates to work on stuff, hes an old codger, but he knows stuff! His son said just replace the power pack( since I have spare parts) he said it might be the big red plug, as they go bad. he said cut out the black/yellow wire and bypass the red plug. well first he said just cut the wire and see if it starts! we talked about all the possible causes and an optical eyes was one. so since he was helping me I wanted to buy something from him and I bought the eye, even though I have a few used ones at home. so with that plan I go home to work on the motor
Sure enough I get home and the motor starts! I DIDNT DO ANYTHING! so now I cant do checks, because every thing is working! so I cut the black /yellow wire and install bullet connector so I can separate the wire if the motor stops again and if that isn't the issue, I can put it back together. I also removed the power pack and coils from my spare motor. I brought all my tools and off I went to the river again. ran good until it started to misfire....it does not shut down, but it missed and bucks at times..sometimes it clears up sometimes it doesn't. but sure enough when I shut the motor off. It wont restart. so I disconnected my black/yellow wire at the new bullet connectors... still would not start. so I pluged them back together and pulled the red plug apart. it looked clean and still had grease from years ago when I put it together.. I plugged them back together and sure enough it started!. so I think it IS IN THE RED plug. this scenario happened about four times, because I stayed on the river, once it restarted , and I used the "unplug and plug, the red plug trick".
now on the motor side of the red plug the wires are exposed , but on the control side all the wires are inside a nice tight solid wire sheathing!! before I cut the sheathing to try and pull out the black/yellow wire, do I have any other potions???
bob
bob
