shan49thomas
Thread starter- Joined
- Jul 17, 2021
- 2
Hello. I have a 1995 Chaparral Sunesta 220 with the 5 liter Mercruiser and a Quicksilver 3000 control with the trailer switch. Everything worked when I purchased the boat but the first time out I found the trailer switch was very loose and ready to fall out. When I went to load the boat it went all the way up but would not go back down. The trailer switch actually fell out and one of the wires was disconnected. Then both became disconnected. So, I have tried to get that new wiring with the tilt/trim and trailer switch but the ones I have seen will not work as the trailer switches on the wiring I have seen are very short and my trailer switch is at the bottom right corner. Much longer than the ones I see. I called a Mercruiser dealer and he said they no longer use that but you only need the tilt/trim switch and you bypass the trailer switch. I have it apart and now I'm not sure how to bypass it. Any ideas?
