Re: Calling all OMC experts, you can't make this stuff up....
Update....as it turns out the distributor was defective as it wasn't advancing properly. However the bigger issue was that the rebuilt carb was heating up (I guess) and starving the engine for fuel. This lead to the popping and stalling. I put the old one back on and wahla. Of course the old one gave me an old problem, the vaccum secondaries do not work. I am chasing the rebuilder to replace the one I bought. <br /><br />This brings me almost full circle (ugh) except it gets to plane much better with the distributor. However, I'm still only seeing 3900 WOT about 23 knots. I have the right prop per Grady/White and supposedly the original out drive. It makes no difference to WOT if I manually open the secondaries and pour more fuel in (I can see it going in), the RPM at WOT remains 3900. <br /><br />I have a stainless prop (same size 15x17) that I will try this weekend, but I already know it won't get me to 4400 to 4800, the factory spec for the 460 OMC King Cobra.<br /><br />Is it only likely to be gear ratio ? All operating parameters are right on the numbers dwell, timing, vaccum, compression, etc.....
