SS MAYFLOAT
Thread starter- Joined
- May 17, 2001
- 6,372
Odd Problem
I've got a 2 door wall freezer. 14" deep, 4' wide, 3' tall. The top, back, and sides normally frost up. This is not frost free and does not have any circulating fans. Normal operating temps are -10 to 0 degrees F.
This unit is 28 years old. TXV was changed 5 years ago when a new 1/3hp condenser unit installed. From that time, this unit has worked flawlessly until now. The left side and back has good frost build up but the top and right end is not freezing. It is not low on refrerant as the sight glass is full, and the head pressure is well within the temp/pressure chart. Condenser coil is spotless as it was cleaned.
From the TXV it seperates into two circuits. One takes care of the left side and back. The other circuit takes care of the top and right side. At first I thought maybe that circuit that was not freezing could have been oil logged or clogged. So, I pumped the unit down, cut the lines to the circuit causing problems. I hooked up my nitrogen tank to the lines and purged the circuit. I only got a slight amount of oil (half a teaspoon) out and it was clean. There was no blockage at all.
I hooked everything back up only for it to repeat the problem. So, today I called the factory tech. He said he never heard of one doing what I described to him.
I mentioned to him that the left side and back had not been defrosted and brought to room temperture. I told the manager to unload (which they were instructed not to use the freezer, but did anyway) the freezer tonight and leave the doors open. Then I will be in first thing in the morning to turn it on and monitor it. The factory tech and I are thinking that with the back and side having ice on them is keeping the unit unbalanced. So hopefully with the unit being brought to room temp will allow the system to balance when turned on. I just hope this is the problem.
If this does not fix the problem, the only other recourse that I can think of doing is putting two new TXV's on. One for each circuit. However, I feel I shouldn't have to do this as it has worked fine for the past 5 years with the new TXV and condenser. The unit is charged with Hotshot R414B which was used when the new condenser was installed.
I've been doing this work for over 25 years and never came across a problem like this. Any thoughts or ideas? Thanks.......SS
