Cam roller cracked in half-missing
jlemberg
I am chasing down an idle stall issue. The first thing I noticed was the Throttle cam roller that Doug and I put on there has cracked off. I know it effects throttle up, but would this effect idle at all, running without a roller? I know that at idle it should be just touching the cam lobe mark at idle, and not opening the throttle valves?
Craig-
Re: Cam roller cracked in half-missing
No, unless a piece of it is hanging something up, but it should be replaced.
jlemberg
Yes going to replace asap. So much for my 5 minute fix.... back to the idle stall. All else is good, had been running fine, it just started cutting out when in neutral. Not sputtering, just a clean cutoff. Starts right back up. Carbs had been cleaned a few months ago(not sure if they link-n-synched), no ethanol marine gas used since. Any non carb tear-down ideas? Compression is good. The only thing I had changed lately was to gas up with Valvtect marine gas(different marinas than usual).
Craig-
Try a portable tank to test first, go from there. May just be bad fuel.
jlemberg
1. Replaced fuel filter
2. Replaced Cam roller
3. Decarbed
5. New plugs after decarb
6. Ran out old fuel-filled with fresh
Not stalling now, and runs/idles alot better.
