KRH1326
Thread starter- Joined
- Sep 22, 2007
- 491
Hey Guys,
I know, maybe this should have been posted elsewhere, but the folks that I want to ask are here, not there.
In the proccess of rebuilding the 3.0 v-6 vulcan in my 1999 Ford Ranger. Pistons, crank, cam, lifters, cyl heads, timing gears and chain, timing cover and oil pan are installed.
Going for the new cam synchro at this point.
Crank and cam are still in the 'just installed' position. They have not been rolled, the keyways and marks are still lined up.
0 (tdc) is right on the mark to the right of the crank position sensor.
Is this my TDC on exhaust or intake stroke? Is this the position that I want to install the synchro??
I am asking when the timing set is freshly installed, and the timing marks are all lined up, what stroke would the crank be in? I'm trying to figure out, in the factory, when they put these together, the timing marks are aligned. When they drop in the synchro, does it go with the timing set marks still aligned, or do they roll the crank once.
Yes, I could postpone synchro install until intake, rods and rockers go in, to roll it over to check the for suck or blow at the plug hole, but I am famous, or infamous, for setting distributers 180 out, so I wanted to try to head this off at the pass.
Thanks for any input.
