dlogvine
Thread starter- Joined
- May 4, 2015
- 839
I am rebuilding 2002 Mercruiser 4.3 v6. I started with freeze plugs a while ago and was waiting for the rebuild kit. Got it a couple days ago and started with camshaft bearings and a balanced shaft bearing. I think I forgot to insert a couple freeze plugs that are supposed to cover camshaft and balanced shaft bores in the back. Since I took the engine apart a long time ago im not sure if both bores are supposed to be plugged (Im almost 100% sure they should be). However i wonder if I can install the freeze plugs with the camshaft and balanced shaft already installed. This is the first question. The second is, what holds the camshaft from sliding back? There is a retaining plate on the front and driving and then timing gear, but neither would prevent the motion of the camshaft back. The other question, in the manuals installation of the driving gear on the balanced shaft states only one thing, not to hit the gear, since it might push the rear freeze plug out. So the third question is how to install the driving gear on the balanced shaft.
I feel kind of dumb since I already rebuild this type of engines a couple times, however they were older ones without the balanced shaft.
Thank you, will post the pictures in a little while.
