camshaft enquiry form
f_inscreenname
Re: camshaft enquiry form
I will let that sink in a little first......
OK Now that you have picked yourself up off the floor. Their stuff is the best. I have built a couple motors through them. As you can see by my avatar (also there is a video page on SuperNova19.com) that I run my boat hard and I have never had one of their parts fail.
Don’t think you will walk away with that price after all your upgrades but I bet you cant beat their prices anywhere. Also Chevy 350's are the cheapest motors to work on, on the planet. Another reason they are cheap. Now you see why I think you should do the bottom end first. There is a couple folks that I turned on to this place here and I have never herd of a complaint. Lots of praises but no complaints.
Last I just rebuilt my motor (because the timing chain cover blew a hole thorough it and let water in the motor) a couple weeks ago.(follow the thread here http://www.forum73.oli.us/nme/index.php/topic,409.0.html ). Now mine is a Chrysler and with next day shipping. the total was 516.00. Also mine has about every upgrade that was offered. 330hp Mopar 360ci that will run it a$$ off all day.
f_inscreenname
You do get this.
INCLUDES
Hastings Rings
Federal Mogul Dish Pistons
Federal Mogul Seal Power Rod Brgs
Federal Mogul Seal Power Main Brgs
Federal Mogul Cam Brgs
Melling Oil Pump
Federal Mogul Camshaft
Federal Mogul Lifters
Melling Timing Components
Pioneer Frost Plugs
Victor Gaskets
These are your upgrades and will ad to the price but you have to do some.
Moly Rings:
moly $11.74
Clevite Brgs:
Clevite Brgs $6.00
Camshaft:
Speed Pro # CS1014R 1500-4000 RPM #CS1014R 278/288 adv duration .420/.443 lift $22.13
Speed Pro # CS1013R 2000-4500 RPM #CS1013R 214/224 adv duration .443/.465 lift $43.64
Crane Energizer Lifter Kit 1200-4200 RPM #100032 260/260 .427/.427 lift (not Computer Compatible) $76.86
Crane Energizer Cam & Lifter Kit 1600-4600 RPM #100042 266/266 Adv duration .440/.440 lift (not Computer Compatible) $76.86
Crane Energizer Cam & Lifter Kit 2000-5000 RPM #100052 272/272 adv duration .454/.454 lift Valve Spring Change is Recomended, Not Computer Compatable $76.86
Crane Energizer Cam & Lifter Kit 2200-5200 RPM #1100172 274/274 adv duration .450/.450 lift Valve springs are recomended changed, 2500+ stall is required, Not Computer Compatible $76.86
Crane Energizer Cam & Lifter Kit 2400- 5400 RPM #100132 278/278 adv duration .467/.467 lift Valve Spring must be changed,2500+ stall required, Not Computer Compatible $76.86
Crane Energizer Cam & Lifter Kit 2500-5500 RPM #100082 adv duration .470/.470 lift Valve Springs must be changed, 2500+ Stall, Not Computer Compatible $76.86
Crane Energizer Cam & Lifter Kit 3000-6000 RPM #100072 284/284 duration .480/.480 lift Valve Spring must be chaned, 2500+ stall.Not Computer Compatible $76.86
Crane Energizer Cam & Lifter Kit 3200-6200 RPM #100182 286/286 adv duration .462/.465 lift Valve Springs must be change, 2500+ stall, Not Computer Compatible $76.86
Crane Energizer Cam & Lifter Kit 3500-6500 RPM #100112 302/302 adv duration .500/.500 lift Valve Springs must be changed 2500+ stall, Not Computer Compatible $76.86
Crane PowerMax Cam & Lifter Kit 1500-4500 RPM #113902 260/272 adv duration .427/.454 lift (Valve Spring must be changed) Not Computer Compatible $107.56
Crane Powermax Cam & Lifter Kit 2000-5000 RPM #113932 266/272 adv Duration 440/454 lift Valve Springs must be changed, Not Computer Compatible $107.56
Crane Powermax Cam & Lifter Kit 2000-5000 RPM #113942 272/284 adv duration .454/.484 lift Valve Springs must be changed, Not Computer Compatible $107.56
Comp 1200-5200 RPM #12-206-2 260/260 adv duration .440/.440 lift Valve Springs must be changed, Not Computer Compatible $76.55
Comp 1500-5000 RPM #12-210-2 268/268 adv Duration .454/.454 lift Valve Springs Must be changed, Not Computer Compatible $76.55
Comp 2000-6000 RPM1 #12-212-2 280/280 adv duration .480/.480 lift Valve Springs must be chaned, 2500+ stall is required, Not Computer Compatible $76.55
Comp 2500-6500 RPM # 12-213-3 292/292 adv duration .501/.501 lift Valve Springs Must be changed, 3000 + stall is required, Not Computer Compatible $89.75
Comp 3000-7000 RPM, #12-214-4 305/305 adv duration .525/.525 lift Valve Springs Must be changed, 3500 + stall required, Not Computer Compatible $98.13
Melling #MTC1 RV Torque cam .420 .443 lift 204/214 dur at 50 $7.88
Comp Xtreme 4X4 #12-235-2 1000-5200 rpm 210/218 duration at 50 .447 .462 lift $79.56
Elgin #CL1787PK 1200-4200 rpm 204/204 dur @ 50 .427 .427 lift $32.33
Elgin #CL1069PK 1600-4600 rpm 214/214 @ 50 .443 .443 lift $32.33
Elgin #CL1065PK 2000-5000 218/218 dur @ 50 .458 .458 lift $32.33
Elgin #CL1784PK 2200-5200 rpm 228/228 dur @ 50 .480 .480 lift $32.33
Elgin #CL1786PK 3500-6500 rpm 246/246 dur @ 50 .500 .500 lift $32.33
Elgin #CL1788PK 2400-5400 rpm 222/222 dur @ 50 .467 .467 lift $32.33
Elgin #CL1785PK 2200-5200 rpm 218/218 dur @ 50 .450 .450 lift $32.33
Frost Plugs:
Brass $6.52
Oil Pump Shaft:
Oil pump shaft for High Volume, High Prssure oil pumps Must use w/high volume pump $6.99
Oil Pump:
High Volume $8.94
Gasket:
Fel Pro # KS2629 $15.78
Timing:
cloyes double roller # C3023XSP $10.79
cloyes true roller # 9-1100SP $21.80
Lifters:
Comp lifters $43.61
Hypereutectic Pistons:
Hypereutectic Pistons Flattop 4 valve reliefs # H345NP $20.12
Hypereutectic Pistons Dish # H423NP $35.30
Hypereutectic Coated Skirt Pistons w/ .125 Dome # H618CP $124.50
Hypereutectic Coated Skirt Pistons w/.275 Dome # H617CP $114.04
Connecting Rods:
Set of 8 Connecting Rods with ARP bolts CR1417X $120.00
Rebuilt Crankshaft:
Rebuilt Crank #1833 2 piece rear main(We will match brgs to crank shaft journal) $65.00 Core value is included in price which will be refunded when returned in orginal box $144.99
New Crank:
Scat New Cast/Steel crankshaft # 9018 2 piece rear main $164.99
These are for the sizes of the parts in question. Some motor have over sized bearings and rings like mine that has had the crank turned .020 under and my cylinders have been cut .030 over. They will not change the price of the master kit.
Wait I think I get it.
It is for this:
Required Options:
*Main Brgs:
*Pistons:
*Rings:
*Rod Brgs:
mtnrat
Comp cams came up with this:
Comp Cams wrote:
I would look at our part number 12-417-8 for your motor along with lifter number
853-16. You will also need shorter pushrod number 7609-16 and I would use rocker
arm number 1416-16 for the Vortec heads which is a self aligning roller tip rocker.
Camshaft Specification Table
Part Number 12-417-8
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS XM 270HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.495 0.503
Duration At 0.006 Tappet Lift 270 276
Valve Timing At 0.006
Open Close
Intake 25 65
Exhaust 72 24
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 112
Recommended Valve Springs 986-16
Looking more like it.
