Camshaft spec's for 1986 OMC 5.7 L 260 HP so I can Pick a new Camshaft during winter
stspinner
Here's what I have 1986 OMC 5.7 Liter 260 HP, will be using q Jet stock intake and exhaust,
Here the stock spec's I found here on iboats and else were on line would like to Verify ;
Intake .390" Lift 195 degrees duration @ 050"
Exhaust .410" lift 202 degrees duration @ .050"
LSA 112 degrees, overlap ?? I think its 91 Degrees
Was thinking about a replacement roller cam from comp cam ? any one know the roller cam spec's on 2008 Mercury 350 Mags ?
I thought this would be a nice size not to big as these idle nice, don't want to big just one size up from stock as the duration can be keep down but the lift goes up pretty quick.
Heres the hydraulic flat tappett; Comp Cam XM 256H rpm range 1000-5000
I .447 " 212 degrees duration @ .050"
E .462 " 218 degrees duration @ .050"
LSA 112 degres , 34 degrees overlap
Hydraulic Roller tappett; Comp Cam XM 264 HR rpm 1200-5200
I .488" 212 degrees duratuin @ .050"
E .495" 218 Degrees duration @ .050"
LSA 112 degrees, 43 degrees overlap
These are the smallest non stock grinds they Have.
Thanks Again ! Scott
stspinner
