camshaft VolvoPenta454 NO Remplacement ?
erick11s
Hi, I have a Boat with old engine, but in good conditions, all stock, with small Edelbrock Manifold, and Carburetor 4 Barrel Quadrajet OEM.
I open the engine and have to change the CAM, ( hydraulic), but I do not want the original,because the VOLVO SAID IS EXPIRE THIS PART... I prefer from another Brand, and one model in a small up grade performance from the original.
What Cam I can choice????????:confused:
This Boat is for family, but again I want to feel small more performance.
Please see the Factory specifications of this boat:
# engine 4100144472
454, Gasoline
Boat BRAND Cobalt 1993, open 27 pies ( see attachment pictures, for better idea)
ENGINE GM made to VOLVO PENTA MOD 740 B YEAR MAKED 1992-1993
Spec: 868498
V-8 4 stroke compression de 8:1
7.44 L. de 330 hp.
MAX 4400 rpm.
USA/VPA
TRANSMISION DP-D
Thanks, for any comments
Erick
jerryjerry05
Re: camshaft VolvoPenta454 NO Remplacement ?
Don't waste your time get a bigger motor.J
bigdan1
Salut ?rik ,
any camhaft with not too much duration will do the job.....consult
comp cam site they have nice marine performance cams .....
is your cam worn out ? rjust want to switch for more ?
Dan ...un qu?becois
Aloysius
Flat tappet cam, right??
ANY stock cam for a big block Chevy from GM will work. GM made only one "marine" cam anyhow. A GM "truck" cam retarded 4 degrees will be just as good.
ALWAYS!! use new or refaced lifters on a new flat tappet cam.
rodbolt
on that cam is a casting number, crane or comp cam or the chevrolet marine guide can find the original GM part number.
you can also use the cam from the 340 horse power mercruiser from about 1986 to about 1993.last I looked merc still stocked it.
Aloysius
Unfortunately, Crane is outa business.
erick11s
Good news...dEAR FRIENDS i CONTACT THE Factory OF crane cams, AND THEY gIVE ME THE SAME iTEM FOR MY ENGINE, IN mARINE GRADE, BEST PERFORMANCE rpm 2000 - 5800, NOT IDLE PROBLEM..i AM HAPPY..PRICE 225 usd
item :#133802 cam and lifter kit ( see the link)
htt
THANKS FOR ALL COMMENTS AND HELP......Erick
Aloysius
I see someone has purchased Crane and is rebuilding the company. Good luck..Crane used to be top notch stuff!
Tail_Gunner
htt
Those numbers 2000-5000 dont look like a marine cam...Actually a very hot cam...You might want to get the duration specs and lsa and post them...
wca_tim
IMHO buy a comp cams xm256H grind... which will sound perfectly stock, or preferably a comp cams xm262H which would run just great and has a little hotter than stock specs, would make a bit more power with a dual plane aluminum intake, etc... just my experience....
