Hi guys, I can’t get the lower unit back on on my 60hp Johnson. I have replaced the lower unit before. This time, I decided to grease the splines. I am able to get the lower unit up to about 1/2 inch of touching but the lower unit just won’t go any higher no matter how much you wiggle it. I even had someone helping me. What could be causing my issue? I don’t think it could be the splines not lining up because the flywheel turns the impeller and I can tell when the splines are not aligned because it stops more like 1.5 inches out with a metal clank. When it stops about 1/2 an inch out it doesn’t really make a clank sound.
