Can a coil die young?
Paddy60
Good day
Two years back I found a non running 1975 70 hp Johnson motor. I cleaned the carbs using the kits and replaced the Rectifier, coils and Power pack. To no surprise, she ran just fine. Late last summer, I found it would idle fine but would not power up. I used the boat very little after and only putting around fearing a clogged high speed jet. I felt confident it could not be electrical with all the new ele parts. It was also hard to imagine I had a fuel issue because I rebuilt the pump, all new fuel lines, new feed hose and tank.
I admit I did have one misshape before I noticed the issue, I hit a stump at a fast idle. It bent the prop a bit. Some time later after the lack of power, I removed the motor cover and noticed the top coil was very loose. I tightened it down but no change.
Now I have taken some time to get her ready for the 2014 season. Checked the compression with a new tester and get 135 psi and all 3 cylinders. Then the 7/16" spark gap test show strong blue spark on the lower two but nothing on the top one. I reset the gat to 3/16" and still nothing on the top cylinder. I have the spare coils from when I replaced them so I will determine if the new coil is dead. Hopefully the coil is the issue and not the power pack or something else!
I assume with the top coil being so loose, the ground wire connection under the bolt holding it on was a bad ground.
Can a bad grounded coil die prematurely? Could this condition also cause other issues with the power pack, stator and Timer base?
Thanks for any advice
Joe Reeves
Re: Can a coil die young?
Remove all spark plugs. Temporarily switch the orange primary wires that lead from the powerpack to the coils from a firing coil to the non firing coil. If the non firing coil now has spark, then obviously the coil is okay.... if still no spark, replace the coil.
Paddy60
Joe,
Can a loose Coil die due to the intermittent grounding? This coil has less than 10hr of run time
Joe Reeves
Joe, Can a loose Coil die due to the intermittent grounding? This coil has less than 10hr of run time
I never encountered that so I can't say. Switch the wires for a test to see if it's bad or not.
boobie
But with a loose coil and running it, it could damage the power pack.
Paddy60
I switched out the suspect coil with one of my old ones and she fired hot and blue at 7/6". Assuming it was loose enough to have a bad ground, I guess I'm lucky not to have burned up the power pack.
Mostly I'm glad it was not a clogged carb starving lube to a cylinder.
Thanks for all the help
