Can a cracked drive shaft housing be repaired?
Nacra52
I have a 1960 Merc 400. I just discovered a crack in the drive shaft housing where the lower unit bolts to it. Can this casting be welded or is it junk?
Thanks, HK
Laddies
Banned
Re: Can a cracked drive shaft housing be repaired?
A good welder with a TIG welder can make it good as new, a hack will turn it into scrap metal
