can a garmin transducer and a eagle cuda 250 transducer
JB
Re: can a garmin transducer and a eagle cuda 250 transducer
As long as they are on different frequencies it would probably work.
Boatist
You can look it up but Garmin and Lowrance both use the same frequencys. 200 Khz and 50 Khz. If they are on the same frequency then they will interfeer with each other. Each will work if the other is off but not at the same time.
