Re: Can a stripped trim cylinder be repaired?
Ayuh,...
The usually Fix is to swap out the whole cylinder,...
Or,...
The Outer Housing is available if you want to swap the guts of it....
The Hole is tapped for an Inverted Flare,....
It would probably take a very Talented Machinest to replicate it....
