Can anybody help with this?
mlschmitz
I have not gotten a response to this in over a week. Could someone please help.
Hello Boaters,
I have an issue with my Merc OB.
At low RPM's the motor sounds just fine. When I get up to 20 on my tach the enging starts to "shake" (this is not a sputter as if it was a fuel problem). When I go over 30rpm and get up on plane the engine sounds normal again.
Any ideas?
My specs:
Tracker by mercury 2 stroke 4 cyl 115hp
Model# 1115412zn
SN# ot463914
Chinewalker
Re: Can anybody help with this?
Sounds like you've got one of the old 2+4 motors. They ran on 2-cylinders at low speed to conserve fuel, and kicked in the other two cylinders as RPM picked up. They had some problems with a less than smooth switchover. There should be some threads on that issue here on iboats if you search around a bit...
