Can anyone help identify these gauges on my 2020 Sylvan Mirage 822
Alumarine
I can't see the back of the 3rd one but they look like dummies to me.
Just to fill in the exisiting panel holes.
JAMeek
Yes the bottom 3 are dummies I’m trying to match the top ones. Hour,Trim,Water temperature.
GA_Boater
The instrument voltage regulator gives you a starting point - Veethree instruments.
Welcome aboard, JAMeek.
JAMeek
That’s where I started just haven’t found exact match yet
Uhhhh.....VeeThree.....just like the tag says.
99% of what VeeThree makes is custom for OEM's and is not in the catalogs. the only ones in their catalogs are the ones they sell thru Sierra. Of their custom gauges, some say dolphin, some say some say honda, some say yamaha, some say searay, some say beneton, etc.
yours are custom for Sylvan
JAMeek
How do I go about getting 3 more that match? That’s exactly what I found out about the gauges. I was just hoping someone else went through the same thing and could help me out more.
you call the customer service desk at sylvan and go thru sylvan. Just understand, they may not exist in the specific configuration if they were not engineered with that face series, pointer series and blue back-light
Even I cant buy those proprietary gauges because of the business agreements, and I know one of the co-owners of VeeThree, just having beers with him yesterday.
your best bet is to call, not email, the customer service department and sylvan and go from there. Sylvan most likely is getting their dash assemblies thru indiana marine who makes proprietary dash panels for many of the manufacturers in Indiana. however I am not certain of that. you would still have to go thru Sylvan. even calling the supplier direct, many of the Tier 1 suppliers of dash manufacturing cant talk to you directly.
JAMeek
Thank you I appreciate your help. I have a dealer going to send them my hull number tomorrow and see what happens? I’m probably going to order the closest ones from Veethree and call it a day.
I would call them. I would ask if you could email the pics of your dash and then ask to see if they can get you part numbers. they may give you part numbers and point you toward a dealer (such as Iboats) to make the transaction.
GA_Boater
Are the gauges not working? The volts and fuel sections seem to be reading.
I was wondering why it's so clean behind the dash. You have a brand new boat.
the OP wants to add additional gauges.
JAMeek
Top gauges work fine the bottom gauges are just dummies I’m just wanting to add Trim,Temperature,Hour gauges. I bought this boat used it is a 2020 used very little.
