Re: Can anyone tell me how many ozs of oil a 40 hp johnson lower end takes
Im pretty sure that model takes 16 OZS to fill.
Did you do it slowly, allowing any and all air to escape? Did you use the pump, or squeeze the tubes? Using the tube method allows quite a bit to leak out. I prefer the pump with the adaptor that screws into the drain hole.
BTW, I hope you replaced the gaskets on the drain and vent screw while you did it. They are for a one time use only. You do not want water intrusion into your lower unit for the cheap price of them.
