Re: can changing prop cause engine to run rough?
It is possible for exhaust restriction in the hub of some props to change engine tune enough to drive the mechanic near crazy.
I've seen it happen. It's rare, but it happens. Usually it's a cheap aluminum aftermarket prop that causes the problem.
I'm with JB, though, with the probably not.
It would help to have more information. Original prop model and pitch, new prop model and pitch. WOT rpm's before and after, etc.
The wrong prop can cause some serious troubles in an engine. Overloading an engine, for instance, can overstress everything. If the ignition is weak, it could cause it to misfire.
hope it helps
John
